Anti-Lock ControlPinpoint TestsPinpoint Test F: DTC C1266Refer to Wiring Diagram Set 42, Vehicle Dynamic Systems for schematic and connector information. See: Electronic Brake Control Module > Removal and Replacement > Anti-Lock Brake System (ABS) Module. TEST the system for normal operation.NoVERIFY BJB fuse 109 (20A) is OK. If OK, REPAIR circuit 483 (RD). If the fuse is not OK, REFER to the Wiring Diagrams to identify the possible causes of the circuit short. CLEAR the DTCs. TEST the system for normal operation. See: Vehicle > Electrical > Diagrams By Number------------------------------------------------- - - Disconnect: ABS Module C135. Measure the voltage between ABS module C135-25, circuit 483 (RD), harness side and ground.
if voltage is greater than 10 volts replace abs module if not
check fuse described in upper section if fuse is bad replace if it blows again you need to check wiring
You can enter you model number in the site above and get a copy of the manual including the belt routing. If this doesn't work for you please send the model number.
Go to the sears web site, then go to parts section, then to owners manual section. Type in model and serial number. Then you can download the manual for free.
Call Hussmann Corp at the number I posted. Give them the model number and serial number and they should help you out. There is also a fax number if you wish to use a fax.
