All lights working but doesn't start. This problem has occurred after scottish water cut off water mid cycle, had to drain the load of washing in the machine at the time but not working since.Is there a way to reset the machine? or suggests on how to fix it?
SOURCE: 2nd Bosch washing machine same problem
put tester on drain pump power wires and see if power is there. if so,your pump or the line is blocked.
SOURCE: WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
SOURCE: Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
SOURCE: bosch maxx 1100 WLF 2260uk.it takes water in but
no drum rotation motor brushes failed cheap and easy to replace.
SOURCE: bosch WET 2820 dryer pumps in water
The problem was the thermostat in the drying inlet chamber. Very easy to get to and very easy to change.
Part No.175369 (NTC sensor)
Regards
PJPJ
