Texas Instruments TI-30XA Calculator Logo
Posted on Jan 25, 2009
HOW TO USE SCIENTIFIC NOTATION
HI,
HAVING A HARD TIME FIGURING OUT HOW TO ENTER SCIENTIFIC NOTATION. PLEASE HELP! I HAVE A TI30XA
  • 1 more comment
  • Anonymous Feb 17, 2009
    How do i eneter scientific notation into this calculator?
  • stephens2099 Mar 04, 2009
    How do I enter scientific notation and graphing functions such as y=2x+1 on my TI30xA calculator?
  • Anonymous Apr 28, 2009
    i am confused i am not sure if 5.6 05 is right
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1266
Points
Z=e over i z= 480 over0.6 z= blank
For my homework i have to figure out what the exponential form is for 16
I am not sure what you mean. Even politicians use the term exponential so it has become blurry.
16=2^4 The power function is related to the exponential.
16=1.6*10^1 Scientific notation. Scientific notation is an exponential display format.
Take your pick.
1helpful
Casio fx-115ms OR ANY scientific calculator
Engineering notation ALWAYS puts the exponent as a multiple of three (kilo, mega, giga, etc). If you want the exponent as it is, use scientific notation. You can put the fx-115EX into scientific notation by pressing SHIFT MODE 7 and then entering the number of digits you want after the radix mark. Unfortunately there is no way to have the calculator adjust both the mantissa and exponent by anything other than three.
1helpful
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Hi, I just bought a calculator model# EL-501W ( by SHARP) and i can't figure out how to plug in #'s in scientific notation? Can you please give me instructions on how to do that??
Without knowing the specific type of scientific notation you are trying to enter, there is no way to give you accurate information. Here is where you can download the manual from...
http://www.usersmanualguide.com/sharp/calculator/el-501w
if you provide additional information, perhaps I can provide a more detailed answer.
Good luck.
I don't know how to use the calculator enough to figure scientific notations
Scientific notation is a number format that has the following structure (d stands for digit)
one digit decimal mark several other digits [times] 10 raised to power of exponent
d [decimal mark] dddddd...[x] 10^ (-) dd
Here are two examples the last two results. The number of digits after the decimal mark is select by the user depending on the number of significant digits in the data. The exponent can be positive or negative.
In you case, to enter x10^ you press the [EE] key (no 10 is entered) the sign of the exponent and the value of exponent.
1helpful
HELP, I can't seem to figure out scientific notations with my Texas Instrument TI-30XA. I've searched for hours on the web. Here's the problem: 7.82 x 10^10 / 63.55 = 1.23 x 10^9. But when I input 7.82 x...
The error comes from the lack of understanding of the meaning of the notation used by the calculator manufacturers.
The [EE] is a "shorthand" notation for times 10 to the power of .
To convince you of it try entering
1[EE]0 [=] this is 1*10^0=1*1=1
1[EE]1 [=] this is 1*10^1=1*10=10
1[EE]2 [=] this is 1*10^2=1*100=100
When you enter 7.82x10[EE]10
you are calculating
7.82*10*1*10^10=7.82x10^11.
Hope it helps.
Scientific notation
Use the EE key
1.234[EE] [(-)]65 [ENTER] 1.234 times 10 negative 65 =1.234E-65
The (-) is not the regular (bigger) minus sign.
Hope it helps
6helpful
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
2helpful
Chemistry problem
You enter a pH value and change the sign to minus, then hit 2nd LOG which is 10^x. The x value is what you're looking for. To put the answer in scientific notation, press 2nd 5 to do so.
Example:
For a pH = 4.1
-4.1 2nd LOG will return 0.0000794
Hiting 2nd 5 will express it as 7.94 -5, giving you the [H+] concentration.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
