Kodak EasyShare CX4310 Digital Camera Logo
helen bautista Posted on Jul 14, 2007
Cannot take pictures
I have a cx 4310 camera. My camera would not take pictures even if i replace my batteries. Befor,when the camera was still working,the pictures also come out dark when we take pictures at night even if there was flash. We cannot even see the pictures we are taking in the screen during nightime.
  • 1 more comment
  • suzzyq235 Dec 21, 2007
    I was getting back photos from an easyshare computer file to transfer to a digital pic frame, now i cannot take any new pics? I've tried changing the batteries several times and the pic frame on this camera is now blank? What can i do, this is not my camera??
  • brakenridge Jul 13, 2008
    With new batteries the green light flashes then turns to red. The camera is inoperative. The problem was solved by cleaning the battery contacts with fine needle nose pliers to reach the contacts and some fine 40 grade wet and dry sandpaper.
  • michael_d793 Nov 05, 2018
    I have the same camera,and cleaned the contacts carefully,but I still get the flashing green,then flashing red light,and the camera shuts off. I am using dollar store alkaline batteries that test good. Would brand name batteries be better?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 17, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
318
Points
Cannot take a picture the lcd is on blank screen
Lens not working-no pics taken-Kodak -Easy Share CX 7300 Camera
"Almost new"
You state it has not been used for over 10 years!
Time to buy a new one as the replace all of the faulty capacitors will cost more than a new camera.
Oct 29, 2021 • Cameras
Kodak CX6200 Battery Door Replacement
Link to purchase of battery door with instructions
One long flash one shortflash five flash? 4310
I need to no where the wires go from my 15.5 h.p.kohler command charging system to the battery
For my Ryobi rp 4310 lock I have no key and dead batteries , can I get replacement keys
yes yo can go on ryobi"s website and you can see if you still have a warrenty or you can get replacement parts
1helpful
My cx 7530 just went blank when snapping a picture. New batteries etc. & will not turn on or off
look for the reset button . This is usually located at the bottom or back side of the camera. use a paper/hair clip to rest it. if still not working, look for a certified kodak tech.
1helpful
Camera remains on even when on off position
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Kodak cx 7525 Will not turn on when trying to take a picture. Brand new Kodak batteries.
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
CX 7525 won't charge on original dock
hi , the charging system is finish , now you have to buy some recharble battery, call that plan B
I Have a Nikon 5600 and it wont take pictures
Make sure you have either a fully charged batteries or a new batteries.
Could be some internal problems such as loose connections.
Camera sounds like it needs repair. Repair for this camera, due to age may be beyond what you would want to spend.
Photo colors are not true on my new Kodak....something wrong?
The Kodak CX4310 is the same as the CX4300 but the 4310 is a Wal-Mart special color. The camera feature that controls color balance is called "white balance" and on the 4310, it is totally automatic. Which means you have no control. If your color is not correct, return the camera. There are not many cameras that use a dock to recharge the camera batteries and connect to the computer. So you will not have many choices if you are looking for a different camera. One camera (without a dock) you should look at, is the Olympus Stylus 300. It is a better choice than the Kodak. It uses rechargeable batteries and the charger is included.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
