Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
