Electronic keypad deadbolt won't turn when lock button is pushed or when code is entered. It is skipping like its not connected
SOURCE: I bought Rona Collections Electronic Deadbolt. My
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
SOURCE: My electronic deadbolt is unlocking
This lock has the capacity for two different codes. Did you program two codes into it? If you did not, there may be a factory code pre-programmed into it and it may be the center button. Make sure you have good batteries and program two codes.
Good luck,
Gary
SOURCE: My Kwikset Electronic Deadbolt is
Here's the installation instruction sheet for the 907-15. Pay particular attention to page 6, where it mentions the left or right-hand installation of the lock, and the need to move the jumper to change the function accordingly.
http://s7d5.scene7.com/is/content/BDHHI/40486-02
