Won't print black
Re. Black stops printing on PS 5510 / 6510.....
If you have followed the usual steps like checking for empties and running a Printhead Clean, then contact HP Phone Support (you can first check if your printer is still in warranty via the link below...
http://h10025.www1.hp.com/ewfrf/wc/weInput?cc=ie&lc=en
Ciara
Hi,5510OR 6510 printhead the same???
The PS 5510 and 6510 have the same printhead, however it is not a replaceable part (it's designed to be integral to the printer)
Try this >>>https://mitchellcampion.wordpress.com/20...
SOURCE: print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
SOURCE: Officejet d135 says bad black printhead- Replace the pentagon --
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
SOURCE: MY HP PRINTER WON'T PRINT
heres a link for the updated driver i hope it works for you http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-73722-3&cc=us&dlc=en&lc=en&os=2093&product=3793939&sw_lang=
