Mitsubishi WD-62528 62" LCD HDTV Logo
Terry Bogusz Posted on Mar 06, 2018
Faint Pink blotches on a white or light colored screen
Had all factory upgrades done to TV 12-03-2010 including NEW Light Engine. Actually was wondering if the guns and rear of the screen needs a cleaning/dusting. We had Hardwood Floors redone 8 months ago and have found excess dust in all kinds of odd places throughout the house since.
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Jul 09, 2007
SOURCE: Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Anonymous
  • 1030 Answers
  • Posted on Jun 18, 2009
SOURCE: tv says air flow problems
ok what you have there is a faulty thernal sensor nitisubishi has issuued a bullitten to serice centers so check with local service center the repair might be covered under warennty
Anonymous
  • 115 Answers
  • Posted on Oct 04, 2009
SOURCE: I replaced my bulb on my wd65731 but screen still
Put the lamp door back on ..:) then rate me
Testimonial: "I figured this out last night on my own, but yes you are exactly right."
Jose Garcia
  • 453 Answers
  • Posted on Apr 13, 2010
SOURCE: mitsubishi wd 62525 timer light blinking. tv was
sorry to give u the bad news but u have a bad control box , the repair on this unit is about $500 , just to give u an idea
Anonymous
  • 27 Answers
  • Posted on Jun 14, 2010
SOURCE: distorted colors on my mitsubishi wd-73727
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
2answers
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
1helpful
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
4helpful
3answers
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
2helpful
2answers
Blotchy screen
You'll probably need a new optical engine for your TV. Sony extended the warranty for some of their LCD projections but I think that the warranty extensions have all ended. Try Sony.com for more info.
1helpful
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Faint red blotches on the screen of my 52inch sony wega
If this is the model with a light engine, then there lies your problem. Your filters in the engine are burning up. The light engine will need to be replaced. If this is an older model with the 3 tubes you might be able to adjust your red green and blue tubes to get the picture back in good standings. Please keep in mind when asking questions to include both the make and model number. This will help us help you more efficiently.
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Hp 42in plasma tv
There is some voltages that need adjusted in your tv and possibly the z sustain board needs replaced if the voltage adjustment doesn't fix it.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
