Our Whirlpool Duet (model # WFW9150WW02) is stopping mid-cycle (on the rinse cycle) and beeping...door remains locked.
SOURCE: whirlpool duet sport washer
F01 finally fixed after 2 repairmen and 2 circuit boards replaced/5 weeks of loaundromat! ! HINT have your repair technician check the boards. Be sure to have them especially check which wires are connected to which areas of the board. It could be that the wires are connected to the wrong place on the board. Good luck!
SOURCE: error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
SOURCE: whirlpool duet sport machine will stop mid-cycle
The display is actually reading "Sd", which is a Suds detect error. This is an indication that you have either used too much detergent, are using the wrong type of detergent, or you have an obstruction somewhere in the drainage system. The following link explains the error code and how to correct it:
http://www.fixya.com/support/r3608687-sud_error
There is a follow-on link included that explains the steps necessary to check the drain pump reservoir. Read through the information provided and let me know if you have any questions. I hope this helps you.
Hello
& Welcome to FixYa
I Agree,
I don't think it is any other board, I believe the CCU (central control unit)
has gone bad as it keeps on stopping mid cycle. If it was the Motor Control
Board (MCU) then the washer motor should have been causing problems (which isn't
the case) so replacement of CCU will be a great option. Please get back to me
if you have any other questions.
Kevin
