When the VCR is first switched on with the tape deck empty, the VCR attempts to rewind. after a few seconds this stops and a flashing error code appears E3, then after a few more seconds this error message turns to E5. there is also a flashing tape symbol shown when the error messages are there. When you try to insert a tape you cannot insert it all the way.
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
SOURCE: Tape is stuck in VCR- Fast rewind and forward
ok sorry man gotta step in Its not the pinch roller as you claimed that picks up the slack on the tape its the pinch roller that would cause wow and flutter in audio on a tape on slower speeds what picks up tape slack is the takeup reel. Theres many reasons why the takeup reel dosent pick up the tape and there fore the unit "eats the tape" it could be a gear assy or even on older units could simply be the rubber drive wheel. Or a belt problem and I know these JVC s really well and its a combo the drive belt as well as the pickup gear assy.
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
SOURCE: DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
