Can't figure out how to reset overload box on side of compressor.
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
SOURCE: uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
SOURCE: Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
It sounds like you are hearing the overload on the compressor closing. When the overload closes the relay tries to start the compressor (that might be the buzzing sound) and if the compressor doesn't start the overload opens and turns the compressor off. You will need to replace the relay on the compressor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected
with a slip on connector. Firmly pull the connector, do not pull on the
wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid
state. If the relay has an exposed wound wire coil it can be tested for
continuity. Otherwise, the relay is of solid state design and requires
specialized equipment for testing.
