I got a screw stuck in the bigger of the two holes behind the chopper blade. When I look down in the hole I can see the screw but cannot reach it with anything. IT looks like there is a second chopper blade in the housing and the screw is wedged between that and the housing. How do I get the entire assembly out like you did in the picture?
Catriver, Great advise and excellent instructions. I had the exact same problem. Once I removed the chopper housing, I noticed the chipper rotated a little snug then got tougher. A couple turns clockwise and counter clockwise and free as a bird.Maybe somenting gooey was stuck.
One thing I did notice after the repair, when motor started, it was growling but quickly stopped. Could this mean the motor assembly is starting to wear??? Is this an easy fix?? What parts are needed and any idea on the approximate expense???
Considering all I have read on the poor service of the Kenmore, I'll look elsewhere next time. 2 years 2 months and I have this problem. Go figure. Thanks for all your help!!!!
Bert, to get to the sump and chopper assy. First remove the lower spray arm by holding the top tab and turning the spray arm off. Next grab a hold of the rear feed and turn it to the right until it unsnaps from the rear feed assy. Now you remove the filter and accumulator assy. It has torq screws, remove and lift off. Now the chopper cover will be on the left, one torq screw and it will lift off exposing the chopper blade. This is probably where it's jammed. Look at the attached pics. It will help you. Catriver.
filter, chopper assy.
chopper inlet,
Take your time and observe what you are doing so you can reverse the steps, this will go real easy. Clean the chopper screen to get good water flow to the upper spray arms.
bert, first check to see if both wires are on the capacitor. The capacitor is mounted to the motor toward the back side. If one of the wires came off, your motor won't run. You may have to pull the dishwasher out. The chopper blade should should rotate with moderate force. If it is difficult to rotate you may need a pump motor assy. The fact that you are hearing the humming tells me that you are getting power to the motor. You can ohm the motor windings. Run windings should ohm at 3 to 7 ohms. Have the capacitor leads disconnected when ohming the motor windings. That chopper screen fits into grooves in that inlet cover, make sure you have that set in right. When all said and done bert, without being there, sounds like the motor is fried. Catriver.
Well, I followed your excellent advice and found the shaft of the grinder had snapped and a pit was lodged under the blade. I replaced the grinder and put everything back together but the problem persists. I am still hearing a humming noise when the wash cycle should be running (after the water has filled). Are there any further ideas about what might be wrong? Is there something that needs to be "reset"? Is there a fuse that is blown? Is the motor broken? Any further ideas would be greatly appreciated. Thank you!
I cant remove the chopper cover. I took the screw out but it won't lift off.
