Samsung SP43J6HD 43" Television Logo
gil87 Posted on Dec 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset lamp samsung sp43j6hd - Samsung SP43J6HD 43" Television
Anonymous
Level 3:
Top Expert:
  • Samsung Master 14,553 Answers
  • Posted on Dec 18, 2012
Anonymous
Samsung Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718440
Points
48227
The quick way if it even has this feature is to call customer service for Samsung or look for the service manual online by model number.
Where is the lamp reset switch
lamp reset is in the service menu of the tv.
If you do this follow the instructions & DO NOT MAKE ANY OTHER ADJUSTS AS YOU CAN GET THE TV WHERE IT WILL NOT OPERATE
website: http://www.fixyourdlp.com/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter-or-lamp-timer/
I have a samsung tv model s6-43w6hd and i need a bulb
The best price for a lamp to the Samsung SP43J6HD is $75.88 at http://www.amazon.com/Electrified-BP96-00826A-BP96-00608A-BP96-00837A-Replacement/dp/B003QL370U/ref=sr_1_2?s=electronics&ie=UTF8&qid=1294330442&sr=1-2 I hope this will help...
1helpful
4answers
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Hi guys I would like to know how old the SP43W6HL is? I have had mine for two years and would like to sell
Look in the back for manufacture date.But as i remenber these set are mostly produced in the years of 2001-2005 the high light of these tvs models.My best estamate as used and good conditon tv.Max price u could get for it about $800 max.
How can I recieve hd channels i have just had a hd box fitted but there is nowhere to fit the hdmi cable to the tv
the cable or satellite box should also have a component input which is the red,white,red,blue and green cables.these will also provide hd quality
The tv switches on and the screen comes on, but then it goes out and the lamp light flashes like there is a problem with the lamp, but how can there be if the lamp lights up? Lamps either work or they...
That is not entirely true. This is not an incandescent lamp, it is a gas filled lamp. When it is about to go out, which includes exploding, the resistance will drop which means the lamp will pull more current. The ballast will sense this and shut down the TV. You need to replace the lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix the unit and where to get the parts. Let me know if you need more help.
Thanks for using FixYa.
hardrocko
My Samsung SP43H3HT picture is blured in parts and writing on screen is duplicated. whats the problem?
It sounds like your convergence STK IC chips have gone bad. They need to be replaced. Good luck!
I have dust spots on screen and is not from lamp miror or screen there for must be from the tubes or lens. how doy you get access to them. thank jose ps. samsung sp43j6hd
they might b come from nywhere so open it and wipe the dust and then close it carefully and use a phone cover to get rid from this
The screen piture will not appear, the lamp light flashes red before all lights flashing, how do i solve, thanks
In this case is best if you replace it, but first, try identifying any awkward noises, if it's clikcing the issue is with the ballast, if it's humming, it's with the color wheel, and if you replaced the lamp already, it's most probable that the issue would be either ballast or colorwheel
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
