When dealing with trigonometric functions and their inverses one has to make sure the angle unit is chosen accordingly.
I am including a few screen capture to help you do the graph.
First, in Home screen Run the NewProb command to reset the calculator and ready it as a clean slate.
Set the correct angle unit. By default, after the NewProb command the angle unit is reset to Radian. If you want something else change it. See picture. Select 1:radian or 2:Degree.
I will use Radian first.
Press the key sequence that opens the Y= editor. Enter Y1=sin(X)
Remember after a newProb command unit is Radian, Window is standard.
Here is what you get.
Here are the window dimension that gave this picture
Now I am going to change the angle unit to degree and redraw a better framed graph. (I could have done it with the radian unit too.)
As you can see I played with the window dimensions (Xmin=-3*180=-540 and Xmax=3*180=540. The Xscale factor was set to 90 and the range of y-values was reduced to -1.2 to 1.2)
Before hitting the Graph sequence make sure that the function to be drawn has a check mark to its left (see the 3rd screen capture from the top).
I reset the ram and it works now.
