Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Incorrect times on wash cycles
My neptune MAH5500BWW font load washer suddenly has the incorrect times on the wash cycles-quick wash 61 minutes, light soil 89, normal 95 and heavy 99. We were away for a week and did lose power, but machine was not in use. Can I reset the times?
  • tpiehl Jan 21, 2009
    I am having the same problem. My wash times are much longer. We had issues with a frozen pipe, so I was not sure if that started the problem.
  • audreyc820 Feb 16, 2009
    My 8 year old Neptune has the exact same problem. The repairman says to use it until it quits altogether ; he could not reccommend putting any money into the machine.
    Waher woman
Tom Zwiebel
Level 2:
  • Expert 318 Answers
  • Posted on Jan 15, 2009
Tom Zwiebel
Expert
Level 2:
Answers
318
Questions
Helped
157125
Points
933
You dont need to reset the times, all that has changed is the soil type. in example, light, regular or heavy. that is what causes the times to change.
you just need to push the options button until it shows the type of cycle you want.
also make sure you have the proper cycle selected and then look to see what other options are selected. you just have too many options turned on, so look at the controls to see what is different then you remember.
  • Criket9627
    Criket9627 Jan 20, 2019
    I use the same options all the time, I know which options to use; my wash time has increased not my options.
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
7helpful
2answers
Maytag neptune mah5500bbw wont spin going through cycle
My Maytag Neptune MAH5500B or MAH5500BWW wouldn't spin either. It would go all the way through the wash cycle, agitation and all, as mentioned before, the spin cycle would start at the 9 minute mark, and get down to the 7 minutes then drop directly to 0 with no spin at all.
After hours of investigation it turned out the balance load switch was corroded. This switch is accessible through the front panel of the washer. The door must be removed and the front panel comes off, this switch is directly under the wash drum where there is a little electrical plug and switch which rests on top of stabilizer styrofoam. The connection was being made but there was green corrosion, and evidently the switch box was corroded within. When bypassed, the washer spun perfectly.
Hope this helps someone else out there - I was horrified to think that this washer would end up more landfill as it wouldn't be worthwhile to pay hundreds for a new motor control board as had been suggested was the problem.
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
1helpful
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Neptune mah5500bww
I've had the same problem with a Neptune MAH3000. I replaced the mother board to no avail. I replaced the timer control to no avail. I then replaced the door lock assembly (wax motor, door switch, etc.) and problem solved. Luckily, I had another machine that I could rob parts from.
My neptune was 30 min for a quick wash and is now 55 min
Terri, you may need to contact Maytag on this one. Here is service bulletin that was released in June of 2002... "Date: June, 2002 No: TDL0008A-S, MAH5500BWW, MAH5500BWQ Issue Software Improvements: A software improvement was introduced to the machine control board. The improvements focused on.  Reducing the number of wet clothes loads, spinning and draining complaints.  Modifications to the time estimation displayed toward the end of spin cycle. Display will no longer fluctuate erratically, time remaining.  ?dO? is no longer displayed when the door is open. Warranty See specific product for warranty information. Action This board modification was phased into production without a series change. Inventory at the National Parts Center was purged and replaced with the new control board." Hope this helps.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
