Anonymous:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
SOURCE: My whirlpool LHW0050PQ4 compact front
probably motor control bd but on some early models when both control bds (1 under top and 1 under bottom panel)came together in a kit worked great since sometimes hard to determine exactly which control bd was actually causing the problem if you are sure wash motor is not running and belt is not off
SOURCE: stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
SOURCE: FH error
Check the strainers on the water inlet valve behind the washer. Make sure they are not obstructed by rust. You need to remove the hot/cold hoses to view them.
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Hi
Press and Hold the Drain/Spin button for 15
seconds, this will unlock the control. Hope this helps...please post back for
further assistance.
Daniel
