I recently received a used Beverage-Air BM-23 keg cooler. I replaced the evaporator pan which was rusted out, door gasket, and evaporator motor and fan blade. The evaporator motor now runs all the time, even when the compressor has shut off. The unit is cooling properly. You have to unplug the unit to get the evaporator motor to shut off. Is this the way this unit is designed, or is there a problem with the wiring? When I replaced the evaporator fan motor I simply disconnect the wiring to the fan and reinstalled the new fan motor. No other wiring was changed or disconnected.
