Older model range takes forever to heat and then temperature fluctuates while baking
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
SOURCE: My pilot light comes on< but the oven will not
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
SOURCE: The oven won't heat on
Hi,You have inspected both the baking and broiler heating elements, and you still can't find a problem with your range/oven parts? Inspect the connections between the heating element and the terminal. You could have a badly connected electric wire, or a burned out electric wire. Range/Oven parts must deal with both voltage and extreme heat, so it's a common problem to have a burned wire from time to time. This is a simple fix and if you check this problem in your initial run of troubleshooting, you may save yourself unnecessary purchases of range/oven parts, etc.
Also Voltage Check can be the problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts.
If OK
Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out
If OK
Check the power at the terminal strip.
Be careful as 240 volts is lethal !!!
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
The oven will not stay hot during baking
