Error code C3452 . how to solve this
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
May be errononous. try resetting the code in "trouble" in the service menu
Konica minolta error codes PRT/IR ERROR P-5
What does the hard drive look like in a Konica Minolta bizhub Imigitics 2520F
konica minolta error code c-1256
i have ITEC B-350 KONICA MINOLTA
how i can fix error c-5101 ib bizhub 600
how i can fix error c-5101 in konica bizhub 600
211 service manual error code 32
53-1
I get error code C-004F when i start my Bizhub C350. How can I solve this Problem?
