Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
John Posted on Nov 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace transmission drive belt on Troybuilt model 13wx79kt011
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Nov 11, 2013
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215253
Points
1078
how to replace transmission drive belt on Troybuil - ?l=troy_bilt&p=76907616%5c0001&nd=0&z=30
THIS SHOULD HELP YA IVE DONE THOSE THAY ARE KINDA HARD THE PULLY ON THE MOTTER IS HARD TO GET OFF YOU MAY WANT TO TAKE THAT IN TO A SHOP
Easiest way to change the drive belt on a 26 horsepower 50.
To change the drive belt on a 26 horsepower 50, follow these steps:
1. Turn off the engine and make sure the machine is completely2. Locate the drive belt on your 26 horsepower 50. It will be located on the pulleys that transfer power from the engine to the transmission or other parts of the machine.
3. If necessary, remove any guards or covers that are
Jul 20, 2023 • Garden
Lawnmower will go in reverse but not forward it's a hydrostat troybuilt what would cause this?
bad transmission, bad drive belt, bad pulley lots of things could go bad try your belt first or take it to your nearest lawn and garden shop they'll uselly charge a 15 dollar diagnostic fee but 99% of the time they'll tell you what it is for sure
May 16, 2015 • Garden
How to remove black plastic cover on ftont of troybuilt self propelled walk behind mower. To expose self prop belt or drive. Took out 2 screws and cover won't come off
probably need to check and see if it's snapped into the sides of the wheel adjusters... next time, including a model number will get you a better answer !!!
Nov 14, 2013 • Garden
1helpful
Transmission drive belt keeps breaking on my troybuilt bronco riding mower
look for a damaged pulley or seized idler they can cause premature failure of a belt
Sep 10, 2013 • Troy Garden
How do i change the lower drive belt on a troybuilt front engine riding mower
On most units you have to drop the deck to change belts, get down there and check it out!! Good Luck..
Mar 23, 2011 • Garden
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 • Garden
1helpful
2answers
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Troybuilt selfpropelled mower Model # 8654R
You can go to Troy Bilt website Customer Solution Center. There you can view/download and print owners manuals. I found the detailed solution to my question there. Best part...it's FREE!
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
