Population Genetics #1 A population of snapdragons is being studied to see if it is in Hardy-Weinberg equilibrium. In snapdragons flower color is determined as follows: RR = red Rr = pink rr = white Let: p = frequency of R allele q = frequency of r allele You count 100 snapdragon plants total: 4 plants with red flowers, 32 plants with pink flowers, and 64 plants with white flowers.
SOURCE: A(24)=40,000e((ln2/26)24)
your best bet in any kind of exponential equation is to set up the general form of the equation and then solve for the constants with the numbers they gave you. With P being population, t being time, you know it is going to look like P=Ae^(b*t) and you are given 2 P's for 2 t's.
So for the first set :
Eq 1 P(26)=40,000=Ae^(b*26)
and the second being a time t=0 P was half the current value:
Eq 2 P(0)=20,000=Ae^(b*0)
20,000=A*1 so A=20,000
now b from Eq 1
40,000=20,000e^(b*26)
SOURCE: does this calculator comes with a standard
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
SOURCE: how do i multiply radicals
To input radical numbers, you need to press the 2nd key and then the x^2 which has the square root symbol in blue above it. Input the numbers of the first radical. Hit the ) button. Then press the multiplication button. Hit the radical button again. Input the numbers of the second radical. Press the ) button again and press enter.
SOURCE: how do I compute population standard deviation on
Put the data into a list using whatever scheme you prefer. Press STAT right-arrow to bring up the STAT CALC menu. Select "1-Var Stats" and specify the list containing the data. You'll get a screen showing the various statistical values. The population standard deviation is designated by a lowercase sigma.
