At the end of the cycle near to 25 min water will be removed but not completely only half and starts displaying 551 with beep and machine stops
Hi i am a technician.This is sensor problem near motor. If problem is not solved by replacing it then call me or whatsapp on +917802911328. I have 100% solution
???? ???? ??? coin ??? ??? ?? ??????? ?? error??? ?? ??
I have 100%solution in SS1 ERROR
A'S COMPANY POLICY
9687500077
Check the drain pump filter and you may have to disassemble the drain pump itself to clear obstructions a paper clip is enough o stop a washer these days.
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
SOURCE: Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
We are also facing the same problem near to 12 min to end of cycle
how to solve this problem
We are also facing the same problem, how the solve this problem?
Same for me too.. Any solution?
drone motor not open pcb is new fixed sir
Hi sir my washing machine giving ss1error code pls tell me
Yes sir wth problem sir tell me
This is problem is drain motor not supply to problem SS1
