SOURCE: U-Line undercounter frost free ice maker refrigerator
All units made today have defrost timers to clear ice from the evaporator. Some of the ice sublimates...turns directly into humidity in the air in the box. It re-condenses in the ice tray area. It is possible that nothing is wrong other than excessive opening of the bin area or the defrost timer is running slow and staying on too long. You may also be consuming the ice too slowly. Can you either change the amount of ice in the bin by adding something to simulate part of the ice content or shut off ice production against low demand?
SOURCE: Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
SOURCE: ice maker shooting water along wall of freezer
Hi...
You need to check this
Regards
PCmania
SOURCE: The bin arm on my Uline Model 402 ice maker broke
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
SOURCE: My u line under counter ice maker (bin, not clear
Can you tell me the model? If its a bi series then it should make ice every 45 min. temps should be 10-15 degrees in bucket. If its a combo then it could take 24 hours to make 1/2 of the bucket.Should be the same temp in your bucket.Make sure you dont have heavy frost in the freezer, Make sure the condenser fan is running and clean.If the temperature in freezer is alot warmer than this and everythng is running then it could be a leak in the system. If its colder than that then set the thermostat to a warmer temperature
