I lost manual and dont know how to set time in Tghk aw 91 516 watch
Here is a link for you...
GSI AW 91 733 Men Fashion Sports Watch Review
SOURCE: CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
SOURCE: i dont know how to set the time
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After,
you have undergone step 1, & 2, or step 1, 2, & 3 (either way
it'll still work), press the mode button and then, minute is ready to
be set or when the minute blinks.
To set MINUTE: press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If
you have only undergone step 1 & 2, or 1, 2, & 3, you need to
press the mode twice. If you have undergone step 1, 2 , 3, & 4 you
need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you
need to press the mode thrice. If you have undergone step 1, 2 , 3,
& 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH: press the start (for higher values) or stop (for lower
values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If
need to press the mode four times. If you have undergone step 1, 2 , 3,
& 4 you need to press the mode thrice. If you skipped step 6, press
the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower
values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
need to press the mode five times. If you have undergone step 1, 2 , 3,
& 4 you need to press the mode 4 times. If you skipped step 6 & 7, press
the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower
values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If
need to press the mode six times. If you have undergone step 1, 2 , 3,
& 4 you need to press the mode 5 times. If you skipped step 6, 7,
& 8, press
the mode 4 times. If you skipped step 7 & 8, press mode thrice. If
you skipped step 8, press mode twice. If you did it step by step until
9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
SOURCE: Set time on tghk watch
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
I had the same question and came to this conclusion. NOTE: I am no expert, but this worked for me (There might be an easier way).
Press the mode button 3 times. When the seconds blink, press the reset button to pick HR/MN/SC. Then press the start button to change each.
