Trimlint manual t-315
SOURCE: I HAVE A TRIMLINE
You will need to check the speed sensor for proper alignment,
cleanliness and function. it should be located near the front roller or
mounted on the motor. It should be within a credit cards width of the
magnet or toothed wheel. If properly adjusted check with an a
multi-meter to see if it is opening and closing by manually spinning the
front roller or motor flywheel. If it isn't replace the sensor.
The sensor should open and close as the magnet passes by. As long as it
is doing this it is good. If the sensor is ok, I would do the following:
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slowly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: need user manual for trimline 7150 treadmill
plelase go to www.fitness.manualsonline.com or www.iconservice.com
God bless you
