A square x b square egual c square the hypotenuse
Find the Side Length of Right Triangle
Use Pythagorean theorem
Case 1
SOURCE: fraction problem
Go into MODE to the second page. In Exact/Approximate, change it to Approx instead of Auto or Exact. This will give you decimals instead of fractions.
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
SOURCE: 8,398 sq. ft.= how many feet.= what per cent of one acre?
An acre (international unit) occupies a surface of 43 560 sq. feet
8398 sq. feet is
8398/ 43 560 =4199/21780 . You cannot go further.The decimal value of the result is 0.19279 which is a little less than 0.20 which is 1/5
Hope it helps.
SOURCE: MY TI nspire always rounds
Turn it on, hit MODE then change the FLOAT value from 1 to Float itself. Float allows you to round, and something changed that setting
SOURCE: My calculator is only rounding
Press 2nd [FORMAT] and select the number of decimal places (9 for floating-decimal).
