Televison & Video Logo
Keith Posted on Oct 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote The TV does not respond to the remote but the remote works on the DVD player
francoise cleofas
Level 3:
Genius:
  • Sony Master 2,432 Answers
  • Posted on Oct 17, 2012
francoise cleofas
Sony Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298135
Points
6852
Does the remote controller is the original remote for your tv ?. if yes and doesn't work the cause is either the IR sensor of the tv is get bad or has a problem in the board.
2helpful
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to www.remotes.com to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
2answers
I need a code # to program my Universal RCA remote for my Prima TV and my DVD player
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
2helpful
2answers
Remote control #15-2147
Toshiba 0749, 1749, 0790, 1285
If that doesn't work then:
If your device does not respond to the remote after
trying all codes listed for your brand, or if your brand
is not listed, try searching for your code. For example,
to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks twice,
then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The
remote sends IR codes from its library to the
selected device, starting with the most popular
code first.
5. If the TV responds, go to step 6. If the TV does
not respond, press CH+. The remote will try the
next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps 1
to 6, substituting the appropriate key for the
device.
IF that doesn't work, I know a great place to find sledge hammers.
TV remote will not work properly
I have a Mitsubishi WD-52725 TV, too, and have experienced the same problems with it. My solution to the remote not responding is to push the reset button on the front of the TV (to the left of the Power button) with a paper clip and wait for the green light to stop blinking (about 1 minute). Then, turn it back on and try the remote again. Recently, my remote stopped responding when pushing certain buttons on it. I removed the batteries, and all of the little screws including the one inside the battery compartment and gently cleaned the contacts inside the remote and the circuit board with a cotton swab dipped in alcohol. After putting it back together, it works fine now.
TV Remote will not work
I was told that there is a short in the power supply, which needs to be built back up. The estimate for repair is $450. Is this reasonable? Thanks.
Hank
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
