This happens to Windows 7 and windows XP computers that has proper drivers installed from the respective CD's come with Product. It this printer a faulty one? Or, this is typical to this printer? (FYI. I have never use this brand before. Never have this problem when use HP, Dell, Canon, etc.)
SOURCE: Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: windows 7 ultimate does not recognise the printe(
32 bit
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=965&filetypeid=0&osid=17
64 bit
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=965&filetypeid=0&osid=18
dont forget to choose your language this drivers actually for vista but its going to work with win7 probably because your printer already Compatible with win7 and there is no new driver so there is must be reason they didnt come up with a new driver for win7 so try to download and install drivers at the above
SOURCE: Hi, My Minolta Magicolor 1600W is
in the control panel right click on the printer and turn off use printer offline..
double click on it and select delete all print jobs,, 1 wont delete
turn off printer double click again and select delete all print jobs
restart pc
in control panel check to make sure all print jobs have been deleted
risght click and select set as default..
SOURCE: windows 7 drivers for minolta magicolor 2300dl?
Two Minolta 2300DL windows 7 64-bit solutions(choose oneoption): 1) Download the XP 64-bit driver and extract to a folder: ftp://ftp.minolta-qms.com/pub/crc/out_going/windows/2300d_64b.exe then Control Panel>Devices and Printers>Add aprinter> Add a local printer>choose USB printer port>select the "HaveDisk" button(do not select a printer) and browse navigate to where you savedthe XP 64-bit driver "MLUU_DRV.inf" driver file which installs and worksfine. Only issue is now have a 3 minutewait delay for each print job using the universal driver compared to no delaywhen printing with XP. OR 2) Follow the Vista USB port(not network) install guide butstill use the XP 64-bit driver. ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf 3) 32-bit option use the Vista 32-bit driver first as thatshould work.
