Konica Minolta bizhub 350 All-In-One Laser Printer Logo
A
Anonymous Posted on Oct 12, 2012
RESET TRANSFER BELT BIZHUB C350
  • himacc
    himacc Jun 14, 2018
    SOLVED
    Change Fuse.: fuse is on the front left side(behind a plastic plate), change for 63mA and it will reset. Is for Konica Minolta Bizhub Fuser and Transfer belt reset fuse's for C200 C203 C253 C353 C250 C252 C300 C352 C350 C351 C450 C451 C550 C650 C452 C552 C652 will save $ 250,=
    https://www.amazon.co.uk/Konica-Minolta-...
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Feb 24, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910706
Points
11959
A new belt will have to be installed at which time the fuse in the new belt will be blown to start a new count from 0. Now you can replace the fuse in the old one if you know how.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 17, 2009
SOURCE: Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
Giamma Giamma
  • 12 Answers
  • Posted on Mar 20, 2009
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Visualpro
  • Posted on Apr 17, 2009
You can try the default admin password which is 12345678
Anonymous
  • 3 Answers
  • Posted on Oct 18, 2009
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Computer hardware and networking support
  • 4281 Answers
  • Posted on Dec 22, 2009
SOURCE: How do you do a
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
So all settings are RESET.
Let me know if you need further assistance.
Thanks for using FixYa.
2helpful
How to remove error C0200 on bizhub c350?
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
1helpful
How to remove error C0200 on Minolta bizhub c350?
Bizhab c350 c13c8
A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
Did you get some 3rd party transfer belt get a OEM and replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How do i replace the image transfer beltt on bizhub 350
there is no image transfer belt on a Bizhub 350. there is one on a C350?????????????????
P22 error code bizhub c350
Clean the registration sensor under the transfer belt or have them replaced also might need to replace the transfer belt
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Image Transfer Belt Installation for Konica Minolta Bizhub C351
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side
9helpful
C-2152 Malfunction
Yes there is a C2152 code for an error with the transfer belt separation. But this code does not appear in the C350 manual. It DOES however appear in the C250/C252 manual. There is a service bulletin from Konica/Minolta about this code that covers models C203/C253/C353. Since it is not covered in the C350 manual I can only assume that if you have a C350 and have this code then it must be a problem with the Transfer Belt Unit or the Sensor Plate. Here is a link to a forum which has the detail on both the bulletins and solutions for this error code. Keep in mind tho that this is not for your exact model. My experience tho (27 years on Minolta's) is that the code for series of machines don't change much. Have you tried resetting the code with the trouble reset procedure?
Good Luck and Thank You for using Fixya.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
