Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
SOURCE: setting Timex 1440 sports watch
mcdevito75 here, For now, you need to know 2 buttons, the MODE and SET buttons, First press the MODE button, you may have to hold it in 2--3 seconds, see the display Blinking, now press the SET button for each function, (hour, minute etc). press MODE after each function is set, after all is set Press MODE for steady display. Here"s Timex Contact number for a manual, 800-448-4639
SOURCE: I can't set my kids timex watch....WR50M...1440
you can find a exper in the watch shop<a href="http://warhammeronline.cheap-wow-accounts.com/" >cheap warhammer gold</a> <a href="http://www.mmostudio.com/" >warhammer online gold</a>
SOURCE: How to change the time on a timex 1440 sports
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX .Rate me, please..
SOURCE: how to set my time
Hi sicadfvsinfu,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3.
Press the bottom left button. This flashes the hour; press the top
right button until you have the correct hour (there is no symbol for am,
pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8.
Press bottom left button, time format flashes (can be set to 24 hour
clock). If correct, you're done. Press top left button if you're done
(can be pressed at any step if you're finished).
To turn off the
chime and alarm: Press bottom left until in the alarm screen. Then press
the top right button repeatedly until the CHIME or CH symbol is gone
and/or ALARM or ALM to disappear, then press the bottom left button to
go back to main time.
Hope it helps.
Thank you for using FixYa.
