Even with a brand-new toner cartridge, which I've taken out and shaken over and over again, I get vertical white streaks on every printout, always in the same places on every page. Obviously something needs cleaning, but I can't find any manual anywhere telling me how to clean anything other than the paper rollers. What do I clean, and how do I clean it?
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
SOURCE: Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
SOURCE: I'm getting a white streak vertically down my
There is a lens inside the printer that has a speck of dust on it. If you pull the Drum cartridge (the green handle) look straight down on the side closest to the fornt you will see a glass peice about 6"x3/8". Dust on this will create a streak like your describing. Do not touch this with your hand! Use a lint free cloth or better a can of dust spray be sure not to tip the can so that the solution sprays out, do not blow on it with your mouth either. You may spit on it! You can usually see the speck of dust. Get it removed and you should be fine.
SOURCE: streaks on printed page full length even after installing new cartridge
i took out my drum and cleaned it with alcohol and then wiped down the inside of the printer anywhere the drum touches with a towel soaked with alcohol and the did about 40 prints and it fixed my pagepro (with each of these 40 prints the the quality got better)
SOURCE: Konica Minolta 2400W shadowy/smeary printing
check the two levers with an envelope on each, to the left and right of the
fusing unit, should be pressed down and not rise up.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
