Watches Logo
robert tincher Posted on Sep 22, 2012
Colibri cx gear 35002 butane lighter
When i push down tab for spark it no longer works.IT is like a lighter that has just ran out of flint. DOES this roperate on a battery?
Sean McCaskey
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 26, 2019
Sean McCaskey
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
9496
Points
12
I repair Colibri lighters and many other brands and models.
I repair all butane lighters including the beam sensor and touch sensor models.
[email protected]
Lillean Leite
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 02, 2013
Lillean Leite
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1979
Points
I.ve got a lighter its silver crome alluminum it reads on both sides a big X with a c on top and us on bottom its butane on the bottom it has a signiture I.D it looks like a snake going up a stick can you help me idenify this lighter it's driving me nuts Thank You Lily
2 Related Answers
damneddle
damneddle
  • 1607 Answers
  • Posted on Aug 09, 2011
SOURCE: i need schematic drawing/picture for
Hello.
Colibri lighters model names are usually "names" not numbers. So, I am not sure if this is what you are looking for:
http://www.colibri.com/assets/files/colibri-product-care.pdf
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 23, 2009
SOURCE: refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
Do you repair calibri lighters
We are FIXYA dot com, we aren't Colibri, we just has a Colibri section for handy filing. We only supply information.
https://www.google.com/search?q=colibri+electro-quartz+lighter+repair
Customer Service - Colibri
https://colibri.com > pages > customer-service
What do I do if my item arrives damaged? Your complete satisfaction is our goal at Colibri.com. Please contact a Colibri.com service representative at (212) 308 ...
Looking for replacement battery for colibri beam sensor lighter
[email protected]
1helpful
2answers
Where to get a colibri lighter repaired
I repair most Colibri Lighters out there. I bought Colibri's repair department. Please check out. Beam Sensor Lighter and Touch sensor.
Cleanlighter.co
[email protected]
1helpful
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
I have a Colibri BOSS cigar cutter lighter. As usual the handles for the cutter have broken away from the blades. The handles are riveted to the blades and so I need at least on blade/handle combo. In...
I have replacement cutter blades for colibri boss lighters.
[email protected]
2answers
My colibri lighter does not want to light up. Have bled tank and refilled. Only a small flame appears.
[email protected]
2answers
Flint spring & screw for monopol lighter
mcdevito75 here, Best Bet, Shop ebay for a similar lighter, flints you can buy at most stores that sell cigarettes.
4answers
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn [email protected]
Jan 30, 2008 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
