HP Officejet 6500 AllInOne InkJet Printer Logo
Anonymous Posted on Sep 22, 2012
New ink only prints pink and black?
Installed all new ink, turned printer on and off. Will print in black or for color options only prints pink and black
303 Electronics
Level 3:
  • HP Master 370 Answers
  • Posted on Jan 30, 2019
303 Electronics
HP Master
Level 3:
Answers
370
Questions
0
Helped
404669
Points
2643
Try soaking printhead in the cleaning solution and it will resolve the issue. Check out the video on how to repmve printhead below. Put it in about half inch of solution which is 50% water, 40% window clening solution like windex, and some ammonia or rubbing alcohol.
Rod Eslinger
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • HP Expert 307 Answers
  • Posted on May 24, 2013
Rod Eslinger
HP Expert
Level 2:
Legend:
Answers
307
Questions
Helped
420134
Points
456
For severe HP OJ 6500/6500A print quality/missing color issues there could be an air bubble in the ink cartridges, air gap between cartridge and PRINTER, or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest. For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Just In Time Tony
Level 1:
Scholar:
New Friend:
  • Contributor 48 Answers
  • Posted on Nov 23, 2012
Just In Time Tony
Contributor
Level 1:
Scholar:
New Friend:
Answers
48
Questions
0
Helped
26614
Points
81
It's possible that your new ink cartridges are actually dried out. I know, they're new but I had 3 out of 4 shipped from a major supplier once and even though it all looked good 3 cartridges were actually a little dried out. Sometimes all it takes is a couple drops of water to get it going again.
I that doesn't work ty this:
More than likely your running out of ink. Check the ink levels first.
If you have Windows 7 you can check this by clicking on the "Start" button at the bottom of the screen, click on the "HP" folder and click on "HP Solutions Center". A graft will come up showing you the printer cartridges levels. Click on the small graft chart at the top right of the screen and the graft will enlage and show you exactly the staus of the ink levels. Click "Print" at the bottom of the screen and it'll run a print test. All 4 cartridges need to be above the "Low" level. It only takes one of them to mess up the print.
If you've got plenty of ink try cleaning the printer head by:
Click "Setup" (just below and left of the LED screen) on the printer.
Scroll the Led screen to "6. Tools". Hit "OK"
Now scroll to "2. Clean printhead". Hit "OK".
This should do it..
5 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
  • Posted on Nov 14, 2007
SOURCE: v40 not printing black, only pink
Print a test report
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
check and see if the colors are ok.
If not see this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&cc=us&lc=en&dlc=en&product=60630&dlc=en&lang=en
Anonymous
  • Posted on Nov 11, 2008
SOURCE: my printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Anonymous
  • 3 Answers
  • Posted on Aug 17, 2009
SOURCE: printer is only printing pinks. Just changed ink
Try cleaning the print head. Do this under the tools for the 812c (do not physically clean). You may have to run the clean utility as much as 5 times.
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on May 13, 2010
SOURCE: I have a brand-new black ink cartridge that is
go to printers & faxies option open that just write clinck on printer icom properties prnter setings just select your both colores u have not setlect back
Anonymous
  • 34 Answers
  • Posted on Jul 03, 2010
SOURCE: Why won't my printer print black with a new ink
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
I have a brand-new black ink cartridge that is most definitely properly installed in my hp deskjet 3550 printer, but the printer simply will not print in black. Every document comes out blue and pink, and...
2answers
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
All colors print only black does not print. New
reset your print option set automatic or color select
2answers
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
V40 not printing black, only pink
Print a test report
If not see this
k24674
Grand Canyon Tech
Grand Canyon Tech
