Nokia 6300 Cellular Phone Logo
A
Anonymous Posted on Sep 20, 2012
Restriction code nokia 6300 - Nokia 6300 Cellular Phone
Anupam Datta
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2013
Anupam Datta
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3011
Points
NOKIA_6300
IMEI 356796023408878
Help me to unlock restriction code.
Thanks
  • 2 more comments
  • Matt Henri Tan
    Matt Henri Tan Dec 01, 2013
    Hello, i need help IMEI 353932014605577 my phone was locked and needs restriction code :((((
  • sandun
    sandun Jun 27, 2019
    NOKIA_6300
    IMEI 356832023706522
  • shafiq
    shafiq Oct 16, 2019
    NOKIA_6300
    IMEI 354181026404202
  • RajabAli Art
    RajabAli Art Jul 05, 2021
    NOKIA_6300
    IMEI 352043029114026
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Sep 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
4152
Points
32
It's Restricted to which country's network,specify it and get the Nokia 6300 model Restriction code at Superunlockcodes.com and unlock it from network lock easily.
zeeshan orakzai
Level 1:
New Friend:
  • Posted on Jul 28, 2015
zeeshan orakzai
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3011
Points
6
Hello
i have Nokia 6300 mobile please help me to unlock restriction code please
IMEI.359811011740211
Munavar Malik
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Dec 02, 2021
Munavar Malik
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
3011
Points
13
Rajib Raj
Level 1:
  • Posted on Aug 26, 2021
Rajib Raj
Contributor
Level 1:
Answers
Questions
0
Helped
3011
Points
13
Rani wadia
Level 3:
Master:
  • Nokia Master 996 Answers
  • Posted on Jan 25, 2015
Rani wadia
Nokia Master
Level 3:
Master:
Answers
996
Questions
5
Helped
417128
Points
2461
Unlock contry code by nokia flashing tool,,,or by an expert professional,,,or freeunlock.com
4 Related Answers
Anonymous
  • Posted on Jun 30, 2008
SOURCE: restriction code to unlock nokia 6300
HI,NOKIA6300 IMEI 354181022702054 PLEASE RESTRICTION CODE.THANKS
Lucky
  • 271 Answers
  • Posted on May 13, 2008
SOURCE: restriction code for 6300
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generator software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
Good Luck.
Live, Love, Laugh.
Anonymous
  • 6 Answers
  • Posted on Jan 30, 2009
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI: 353508029865248
Your unlock code is: 426850229882845
Manufacturer/Model: Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is Phone Restricted”. Select “undo” by pressing the middle soft-key button. (Different message? See FAQ below)
6. Carefully read step 6 before attempting to enter the unlock code. This step has the potential to PERMANENTLY BLOCK YOUR PHONE!
Enter into the phone #pw+ followed by the 15-digit unlocking code then +1# (Unlocking code is shown above). Do not enter the 15-digit IMEI number by mistake
To enter + press the * (star) key two times
To enter p press the * (star) key three times
To enter w press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it disappears? See the FAQ below)
7. Then press OK
8. The handset will display Phone restriction off unlocked after successful entry of the unlocking code. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Anonymous
  • 110 Answers
  • Posted on Feb 15, 2009
To unlock mobile you have to give your IMEI number which is back side of the mobile,just remove the battery,you will got it.
What is restricion code
Restriction code and network unlock code is same..Nokia Phone asks restriction code..If your Nokia Locked to network and you are trying to inserting other GSM Network sim card it will display the message "Enter Restriction Code" Without unlocking it you cannot use other GSM Network sim card.After Unlock it you can use only gsm sim card...
You can get the Restriction code from service provider,but they ask to wait for many days or months.
So you can get the Restriction code for Nokia 6300 easily from the site
Mobile-unlocker.com/nokia-6300/rs2wp9/ and unlock it easily...To enter the code you can follow the instructions below:
Nokia 6300 Unlocking Instructions :
Warning : Do not enter any wrong unlock codes on your Nokia 6300 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 6300 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
I need restriction cod for nokia 6300
If your mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 6300 model mobile can be got at Superunlockcodes.com which gives easy instructions to unlock your mobile.
Restriction code to unlock nokia 6300?
I don't know the restriction code...You can get the restriction code for Nokia 6300 at here Theunlockspot.com/nokia-6300/rs10wp9/ and Unlock it..
7helpful
2answers
Restriction code for nokia 6300. IMEI352939028760935
IMEI: 356864024630484
Network: T-Mobile Macedonia
Please I need restriction code
2answers
What's your problem?nokia 6300 restriction codes imei number352939/02/354728/7
Restriction code is nothing but the unlocking code for your mobile.
Unlocking your phone just removes the SIM card restriction so that you can use other network's SIM card.
To get the restriction code for your Nokia 6300 model mobile, just visit this site http://www.theunlockarena.com/nokia-6300/rs13wp9/,In this site just give your IMEI number , country & network lock after that within a short period
you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
Restriction code
Restriction code is nothing but the unlock code ,
Get the restriction code for your nokia 6300 model mobile here Superunlockcodes.com , it gives the easy instructions for getting the restriction (unlock) code for your nokia mobile at a safe way..........
3helpful
6300 Cellular Phone: i need a nokia 6300 restriction code...
you can unlock it here http://www.superunlockcodes.com/nokia-6300/rs12wp9/
3helpful
3answers
Unlock the Restriction Code for Nokia 6300
i have the Nokia 6300 i want to unlock the restriction code
type rm 217
model 6300
ic:661u-rm 217
fcc id ppirm -217
made in hungary 359810/01/817126/3
ce 0434
Unlocks.co.uk can supply a restriction code for the Nokia 6300 from only £3.00. Ordering an unlock code for your Nokia 6300 is very simple - click on the Nokia Unlock Codes link in the menu, select Nokia 6300 from the list, complete the secure online order form, complete your payment through the PayPal payment service and sit back, relax and wait. Your Nokia 6300 unlock code will be delivered via email usually within 24 hours, however please allow up to 7 workings for delivery.
3helpful
3answers
I need restriction code for nokia 6300 my imei number is 352042026998852
my brother send a mobile(nokia 6300) from ireland to pakistan.but there mobile is not working.the useless need a restriction code.so plz help me and send a restriction code now.i m waiting sir.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
