And also I want to know how to reset the pickup roller counter by placing the printer on "Tech Mode"
SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
SOURCE: CLX-3160FN askes for replace TRansport belt, is it a
replace belt,take drum out slide transfer belt wich is located ontop of drum.see how it is connected,slides in/out.
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
SOURCE: hi, i'd like to get
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 9.7px Helvetica}
press menu->ID Copy->Left->Right->Menu->Black Start consecutively
SOURCE: Hello, how can I enter "Tech mode" on CLP660N for
For some other Samsung CLP printer types it works like this:
1. Enter tech mode Menu>up>left>ok>right>stop>menu
2. Select Data Setup
3. Select Counter Reset
4. Select Fuser
5. If it asks, select OK.
Once it has gone through the process just go back to main user screen.
