Samsung CLX-3175FW Multifunction Laser Color Printer Logo
vi sith Posted on Sep 14, 2012
Samsung clx-3185 sensors error #A3-3311 - Samsung CLX-3175FW Multifunction Laser Color Printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3276
Points
Sensor failure #a3-3311
  • Anonymous Dec 01, 2012
    soliuton pls
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Feb 26, 2009
SOURCE: Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Anonymous
  • 12 Answers
  • Posted on Jul 10, 2010
SOURCE: deve home sensor error
This can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Anonymous
  • 12 Answers
SOURCE: deve home sensor error on samsung clx-3160
Below steps are for the CLP-300 which has the same Imager/Developer. It's just a bit more involved taking off the top in the CLX-3160.
Anonymous
  • 12 Answers
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Anonymous
  • 12 Answers
SOURCE: samsung clx-3160fn deve home sensor error
Samsung clx 3185 printing is all faded, colors and black
When you go to print, your printer driver should have quality options. Make sure you're not using "economy" or "draft" mode. Try "quality" mode.
How to fix image unit error in samsung CLX-3185
hi, please clean the drum unit contact,the then put in to the printer
Output bin full
there is a sensor in the compartment that your paper comes out in to. it must be stuck or broken
Samsung clx 3185 error code u1-2112. turn power off and on but still wont fix the unit
firstly restart the printer, if same error is comimg.
then,
fuser error. replace fuser unit
2helpful
2answers
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
