I downloaded some pics from the camera to the Pc. A little later, I went to take a picture using the front screen. Now the front screen has multicolored vertical lines, and no picture. Help?
If something is broken you will need support, perhaps under warranty.The support site is here:
http://www.samsung.com/us/support/owners/product/EC-PL120ZBPBUS
and troubleshooting here:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=368703&modelname=SAMSUNG+PL120&modelcode=EC-PL120ZBPBUS
If the problem is down to operations or settings, the manual is here:
http://downloadcenter.samsung.com/content/UM/201107/20110730115442933/PL120_PL121_English.pdf
SOURCE: Samsung i5 camera
the photo is not being displayed when the camera is connected to the computer.however the phot can be viewed in the camera.
SOURCE: Camera won't turn on
not sure if you have the same problem..but i have the same camera and when i turned it on the screen was all white..it still worked and took pictures but i could only see them on the computer.. i had my friends dad open it up and he found a foam like piece that fell from somewhere and was causing a wire to short out in the LCD screen.
SOURCE: samsung digimax 350se- i am having problems getting pictures off of camera
i do not have the software from the camera (cd) and my computer is no recognixing the camera, is there a website i can go to download this software so i can get my pics from the camera to my computer
SOURCE: Downloading Pictures from Samsung L100
Make sure you have the driver downloaded, if so go to My Computer and see if connection is valid if not it could be your port or cord.
SOURCE: pics turn white with lines when taken outside in day light
Check to see if your ISO is set to a high number like 800 or 1600. If so, set it lower or on auto ISO. Your white balance should probably be on auto white balance. Go into the setup menu and see if your camera has a setting for "reset". This could take your camera back to factory defaults.
I've also gone through the menu settings on the camera, to see if I could change this so the vertical lines went away. Nothing. The camera has not been dropped, gotten wet or anything like that. It was a simple picture download to a pc, and then this happened.
