If you have changed the toner cartridge, the printer must
complete a
calibration cycle (up to 150 seconds). If you open the door before the
Ready indicator on the control panel lights up and the Error indicator
turns off, the printer stops and repeats the calibration cycle.
1.
Open the Status Display (double-click on Status Display icon in the
system tray on the lower right-hand portion of the task bar, OR click
Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA
magicolor 2300W Status), and then check which toner color is empty.
2. From the
Print menu choose
Toner Replace...3. In the
Color list box, select the color of the toner cartridge to be replaced (
CYAN,
MAGENTA,
YELLOW, or
BLACK).
4. Select the capacity of the new toner cartridge (
1500 or
4500).
5. Click
OK.
6.
When the toner indicator on the control panel starts flashing, open the
printer's front door. The carousel is automatically repositioned so
that the appropriate toner cartridge can be removed.
7.
Insert your thumb and index finger into the two holes in the front of
the toner cartridge, and then pull the cartridge straight out about 6"
(15 cm).
8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each
toner cartridge has a colored end that corresponds to a color inside
the cartridge slots. Always install the toner cartridge in the slot of
the same color
.Each
the same color.
11.
Support the middle of the cartridge with your left hand, insert the
thumb and index finger of your right hand into the two holes in the
front of the toner cartridge, and then insert the cartridge so that the
guides on the cartridge fit into the rails in the cartridge compartment
in the carousel.
12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The
printer must complete a calibration cycle (up to 150 seconds) after any
consumable has been replaced. If you open the door before the Ready
indicator on the control panel lights up and the Error indicator turns
I replaced the magenta and cyan colors in my printer but now the printer is telling me that i need to replace them again, even though it says that the colors full WHAT SHOULD I DO?
