Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
A
Anonymous Posted on Aug 23, 2012
Where can i buy replacement string for a homelite ut20760
5 Related Answers
Anonymous
  • Posted on May 16, 2009
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jun 19, 2009
SOURCE: I have a Homelite gas trimmer model UT20760. It
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Jul 03, 2009
SOURCE: How to change the string
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Anonymous
  • Posted on Jan 09, 2010
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 10, 2011
SOURCE: Need fuel to oil ratio
50:1 2.5oz. of 2 cycle oil to 1 US Gallon of gas.
Jim
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 • Garden
1helpful
Model ut20760 trimmer engine parts list
Here you go. See page 5 for engine parts. This link has the whole machine.
http://www.odref.com/homelite/string-trimmers/ut-20760-note.PDF
You will need Adobe Reader on your computer to view this parts list.
Apr 19, 2011 • Garden
What type of string do I buy for my homelike weed eater
Without knowing your model number, the typical string for the Homelite trimmers is .080" string.These types of units use that:
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
2helpful
I need to know the proper gas/oil mixture.
Hello. 40 to 1,or 8oz 2 cycle oil to 2.5 gallon of gas, or 3.2oz of oil to 1 gallon of gas. Joe
1helpful
Where do I get a replacement screw for the muffler. Homelite Trimlite Model UT20760.
you can take your trimlite in to your local hardware store and match the screw right there in the store or go on line to homelite dealer to order. hope was some help
Jul 11, 2009 • Garden
2helpful
2answers
Problems with my HomeLite UT20760 bogs down, no power
try this
you need to locate your muffler and find screws that remove a screen behind a plate you can remove on the muffler or behind the muffler itself
This screen is a spark arrestor screen and needs to be cleaned and put back or some would say discard all together, but i didnt say that.
give it a look see
this may be your problem and maybe not?
if it was you will see a trmendous difference afterwards
4helpful
3answers
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
