Top half of screen is fine. Bottom half is green.
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
SOURCE: My sony bravia tv's picture is so wide it cuts off
change picture format to 16.9 in the menu or if there is button on remote ( aspect / format or zoom ) or a picture of a square with two lines in it press until picture look ok
SOURCE: 3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
