Cars & Trucks Logo
Anonymous Posted on Aug 16, 2012
2002 hyundai elantra keyless remote not working after changing battery
I just changed the battery in the keyless remote key fob, and the doors do not work with the remote. How can I reprogram the remote. Or reset the reciever?
  • Anonymous Mar 23, 2014
    how do I replace the battery on the remote control
Anonymous
Level 3:
  • Master 786 Answers
  • Posted on Aug 16, 2012
Anonymous
Master
Level 3:
Answers
786
Questions
Helped
245851
Points
2462
Try disconnecting battery in car then reconnecting...might help.
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Nov 01, 2008
SOURCE: how do you change battery in key fob on 2002 vw golf
No problem. The key fob is two pieces. The key part and the remote. Open the key as you would to sue it. Where the key flips open you can see a small recess about where the line of the trunck switch. This is where the key separates. You can pull it off or pry it with a small screwdriver. Once separated with remote part in your hand this also splits in 2. In the same area you split the key off insert the screwdriver in this recess and the fob will open giving you access to the battery. Also can be done by hand. It is a little tight so you will have to force which is normal. No screws just clipped. Make sure the battery is positioned in the right way and that you have 3 volts when you test the battery. 2.7 volts will make the remote not work or act funny.
SIMON SEAGER
  • 13 Answers
  • Posted on Dec 01, 2008
SOURCE: focus remote key fob not working
this info would cost you £30.+ at ford Radio Frequency Programming Instructions:
  • Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.
  • Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED (By the clock) stays on continuously to indicate this.
  • During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED.
  • Wait until learn mode times out (20 seconds) or switch the ignition back to ON.nfrared Programming Instructions:
  • Put your key into the ignition and turn to position 1 (Radio). After approximately 10 seconds the red alarm control LED (next to the clock) should illuminate. As soon as it comes on remove the key from the ignition - the LED should remain lit.
  • Point the remote's "eye" at one of the front door sensors and press the rear button until the light on the transmitter illuminates (Keep the button pressed)
  • With the rear button held in press the front button 4 times then release both at the same time. The control lights in both clock and fob will flash 4 times to indicate programming complete.
  • Turn the ignition back on to exit programming mode
Anonymous
  • 140 Answers
  • Posted on Mar 21, 2009
SOURCE: 1997 Toyota Avalon Key Fob is not working
you can take it to a dealer and they can reprogram it for you.. good luck keith...
Anonymous
  • 2004 Answers
  • Posted on Apr 14, 2009
SOURCE: key fob for hyundai elantra not working
Please dont worry yourself so much the security locks needs to be reprogrammed to enable it work effectively. Same happens to other vehicles as well.
Consult Hyundai garage close to you or if you have it in your manual.
Good luck.
rate this.
Anonymous
  • Posted on Apr 11, 2010
SOURCE: car key fob not working and locking car
i have a rover 25 and the key fob is not opening the car i could use the key to open it but the alarm will go off and cant stop it without the fob...
2answers
Changed battery in keyless remote and now doesn't start car or open doors
  • HOW TO - Change the battery and quick fix your car remote ...
    ? 9:32
    https://www.youtube.com/watch?v=KzCXGXCe0oc
    Sep 1, 2011 - Uploaded by tyreeztt
    Also if your remote isn't working with a new battery please check out this ... TO - Change the battery and quick fix your car remote / keyless entry ...
    Remote Key does not lock / unlock doors after battery change ...
    www.6speedonline.com/.../208274-remote-key-does-not-lock-unlock-do...
    Apr 17, 2010 - After I changed the battery, it would no longer lock / unlock the doors. ... I can start the call and all .. its just the door and trunk lock / unlock function that does not seem to work . ... now your fob is learned... the keyless entry goes into a "sleep" mode to preserve the batt.. if u do not use the ... Still don't work .
    how do i reprogram my lock remote to my car? i changed my ...
    www.cargurus.com > Questions > Hyundai > Tiburon
    CarGurusAug 17, 2009 - i change my battery an now my lock an un lock buttons dont work on my remote how o i reprogram it? ... I have a Hyundai 2003 Tiburon, and the followingworked for me, get ... However for a replacement keyless remote fob, you will have to go to ... And no, they don't do it for free (ranges from $30-$50 in my ...
    Top 5 Tips in Fixing a Keyless Remote ' eBay
    www.ebay.com > ... > Safety & Security > Keyless Entry Remote / Fob
    Key fobs that don't permit entry can be a major hassle for drivers, but fortunately, there... Drivers with a bit of basic electronics experience are often able to replace their ...After confirming that a remote is faulty, try replacing its battery. ... like "Jeep Wranglerkeyless remote," to find listings that will work with specific vehicles.
1helpful
Can a remote start be installed in a car with NO KEYLESS ENTRY? no alarm system...just a key to open doors
Yes. After market remote start kits don't care about keyless entry or alarm systems. You will get a separate key fob to operate the remote starter.
My 2002 jeep liberty door locks keeps making a clicking noise when I drive. Weeks later now the keyless remote want work. I changed the batteries. When I drive the door lock will lock in 15 seconds. I have...
Sounds as if the key remote had one of its buttons stuck down.this happen to me when a girlfriend used her nail to press the remote and the rubber flap got pushed inside the fob and kept the remote sending signals.unfortunately you can't just swap out batteries as most key fobs have to be reprogrammed.if you use the dealership that your make is serviced by it is better to ask how much they charge as sometimes independent auto locksmiths can reprogram key fobs cheaper.
My remote battery is died when i am opening the door by key the alarm goes on! what can i doe abouth it?
you can have a shop reprogram the reciever in the car to accept the remote. once the battery is removed from the remote it resets the code it transmit (Rolling code)
4helpful
How do I reprogram the key fob on my 2005 Hyundai Santa Fe without having to pay the fee at the dealership?
Well, you basically have only 3 choices:
1. Pay the fee at the dealership
2. Purchase the high-dollar equipment that is required to perform the programming procedure
3. Forget about adding another key fob to tor vehicle.
TECHNICAL SERVICE BULLETIN
Group
90 - ELECTRICAL
Number
03-90-020
Date
October, 2003
Model
Elantra 2001-2004, Santa Fe 2001-2004, Sonata 2002-2004, Tiburon 2003-2004, XG(NNN) NNN-NNNNand XG(NNN) NNN-NNNN2004
Subject
SECURITY SYSTEM KEYLESS ADAPTER CABLE
This bulletin supersedes TSB # XXXXX
DESCRIPTION:
The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03 or newer) and Data Link Connector (DLC) Cable.
SERVICE INFORMATION:
The keyless adapter cable can be used on the following vehicles:
^ 2001 -2004 Elantra
^ 2001-2004 SantaFe
^ 2002 - 2004 Sonata
My alarm remote wont work. We changed the batteries. What do we have to do now.
My 2002 hyundai santa fe 2.7 fob will not open the doors or activate the alarm on both fobs, it has just stopped working, I have changed the battery and the led light on the fob lights up when pressed. any ideas?
3helpful
2008 Hyundai i30. 2.0 litre petrol. (Elantra selected, since I believe i30 is same basic engine system as the Elantra, and i30 is not a provided option for my model on this forum). Car won't start. Engine...
Interesting problem.. since not US spec. Is there a 'remote keyless (fob)' programmed for this vehicle? That's the only way to DE-arm the immobilizer (anti-theft) feature (based on US specs). Unless you have this key fob (keyless entry remote... which must also be programmed for this vehicle), the only other way is wait 5 minutes with the existing key in the ignition, then it should start (US specs). You will still need to have an 'ACTIVE' keyless remote programmed for this vehicle... otherwise, you'll continue to run into this problem.
Car wont lock with the button
are you trying the key fob remote. an aftermarket radio can affect keyless entry systems.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
