How to change decimal to fraction on ti 84
SOURCE: TI-89 decimal to fraction
Here is what you do:
1) Press the Mode button.
2) Scroll down the list that appears until you find "Exact/Approx".
3) Change the setting for "Exact/Approx" to Exact.
4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx":
1) Auto - The calculator will try to determine the best format.
2) Exact - The calculator will always give the answer in fraction form.
3) Approximate - The calculator will always give the answer in decimal form.
SOURCE: fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
SOURCE: fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
SOURCE: decimals to fractions
Use the [2nd][MATH] keys. Scroll right [F6] to the softmenu [->Frac or To Frac].
Hope it helps.
