After installing OS X 10.8 Mountain Lion on my MacBook Air, I can't access many of my saved Excel documents or any Excel documents that are emailed to me. I get an error message saying that the file "may be read-only" or that I "may be trying to access a read-only location, or the server the document is stored on may not be responding." My documents are saved on Dropbox. Yahoo is my email server, and I've tried going to Yahoo from both Firefox and Chrome. If anyone has a fix for this problem, your feedback would be super appreciated! THX!!!
Try repairing disk permissions by running the Disk Utility application until you get no errors (then restarting).
Hope by doing that you get the solution.
Testimonial: "It worked! Thank you so much, Banjade! I was under the impression that you needed a second internal drive to run the Disk Utility, but that's obviously not the case. What an easy fix! I will run Disk Utility more often. Thank you!"
SOURCE: Mac OS X 10.5 iDisk error -35
Give your mac a few moments to wake up before you try to connect iDisk.
If this didn't solve your problem
1. From the Apple menu, choose Log Out.
2. Log back in.
3. Try to connect to your iDisk.
4. If the issue persists, restart your computer.
You should now be able to connect to your iDisk. However, if the issue persists, follow
these additional steps:
1. Open System Preferences.
2. Click MobileMe.
3. Click Sign Out. Note: This will unregister your computer from syncing with MobileMe, and disable iDisk Syncing if it is enabled.
4. Retype your MobileMe account name and password.
5. Connect to your iDisk.
SOURCE: how do I edit the hosts file on a mac
You can also use Finder:
'Shift + Cmd + G' will open up the 'Go to folder' window.
Enter '/etc' and you will show up in a new folder where the file 'hosts' should exist.
SOURCE: Mac OS X 10.4 Installation problem
can you help me about my problem about intallation of mac os 9.. i have a G3 model of macintosh iwant to convert the mac os to windows. my question is is it posible to convert then mac os to windows? how? can you hel me.?
johannes
from philippines
SOURCE: mac laptop keyboard locked
im sorry to tell you that most likely you have gotten some sort of fluid down into the keyboard wich has shortcircuited it.
Why did you wipe it in the first place? did you try to remove something you spilled? or was the cloth you wiped with wet?
SOURCE: MAC OS 10.4 Shared Folder problem
The user has to connect to the mac on which the folder is shared, only after that can the user access the file. I t would be helpful if you could tell me the os type of the other machine.
