There is a whistle inside the computer that happens everytime that i turn it on. it tells me that it unexpectedly shuts down to protect my computer. i hit enter and it continues.. tries showing me a message, but my screen gets covered in all sorts of colorful lines so i can't see what the message says and then it shuts down again. I have only had this computer for 20 some days.
SOURCE: PC crashes repeatedly, sometimes comes back on, screen says this!
this problem is cause by some hardware components. just make sure all of your hardware components are fixed correctly with mainboard. or else, if you installed any new hardware options to your computer, just remove that & try to start the computer.
if you still have that problem, just let me know!!
Testimonial: "Thanks so much, but I ended up having it worked on to clean out the dust and its working great!! Thanks!!"
SOURCE: Machine shuts down when loading Windows
hi looks very confusing to me....fist u say pc is running the it turns off.....but also RUNNING....what is running/? is power to ur pc on or off/? as u also say u have to disconnect or pc from the power outlet....looking all this means to meu have a problem with ur powerpac and needs replacing or ur setting is wrong in power option
u can email me on [email protected] and i may be able to help u more if u give me more details
cheers
SOURCE: computer screen blank
Your operating systems is using a resolution out of your monitors capable range. Hit f8 during boot and select VGA mode. Once in change the resolution.
OR
Your operating system is using a different output. Once in VGA mode check the display properties and make sure your primary display is your monitor No. 1. To get into display properties right click your desktop and go to properties.
SOURCE: emachine w5243 keeps shutting down
hELLO THERE:
I WOULD SUGGGEST TO DOWNLOAD CCLEANER IT IS A FREE MALWARE AND VIRUS DETECTION REMOVAL IT IS TOTALY FREE AND HAS DONE WONDERS FOR ME AND MY FRIENDS
SOURCE: When my computer sits for
Sounds like a heating issue. Look inside and check that the chassis , video and processor fans are working. You may have to clean the fans.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
