Can u pls advice how to fix this problem
thanx
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
well, this was helpful to know that I needed to wait on the copier repair tech to come and fix the problem. But what was the biggest help and blessing was your signature tag....Today's the best day of my life...and NOW you're part of it! WOW! In the midst of an extremely stressful week, what a blessing to have that be a reminder to me to push back and see that I should be looking at each and every day in this manner. THANK YOU SO MUCH for your encouraging words. May God bless you!
Today's the best day of my life...and NOW you're part of it!.....what a reminder to me in the midst of an extremely stressful week that I need to push back and look at each and every day in this manner. What a blessing! Thank you so much for this encouragement. May God bless you!
Relevant Electrical Parts
Main Motor (M1) Mechanical Control Board (PWB-M)
DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
Check the M1 connector for proper connection
and correct as necessary.
Check M1 for proper drive coupling and
Check the PWB-M connector for proper
connection and correct as necessary.
M1 operation check PWB-M CNDM1-5 (REM)
PWB-M CNDM1-8 (LOCK)
L-2
5 Change PWB-M — —
6 Change PU1 — —
C-5102 is Main Motor failure to turn. Open close front door to reset. If code comes back remove the transfer belt check the transfer belt proper operation. Next check the connection to the main motor. Replace the main motor, worse case the board that controls it is bad.
While printing, received this code message, and of course - its saturday. How can I fix this?
