Not able to tun the samsung tv on / off with samsung blu ray bd 6800 remote
SOURCE: When trying to connect my 4695D to a new Sony Blu
The problem has been solved. A previous post to this site was having a similar problem hooking up a Playstation Blu Ray player to the same TV.
A solution was posted to that problem and I followed the same instructions.
It has to do with the set up porgram on the Blu Ray component. You need to select Settings then 108024Bit needs to be set to off.
SOURCE: I have a Samsung UN55B7000 tv and a HT-BD3252
Make sure you turn on the surround sound located on your remote, should be second button from the bottom all the way over on the right.
SOURCE: i have a samsung tv and samsung blu ray i have my
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
SOURCE: why does my samsung lcd
Hi.
It is a factory defect affecting certain Samsung LCD TV models. The problem is consequence of a defect in design of terminal connections circuits hosted in main board.
Sometimes getting a better HDMI cable may help reducing or getting rid of the problem. Disconnecting other devices connected to the TV may also be a workaround.
Call Samsung at the number listed in the owners manual. The alternative is replacing an expensive TV main board.
Here one of the several websites reporting the same problem.
Here US contact: Contact Us - SAMSUNG
Regards.
Ginko.
SOURCE: HI YA IM HAVING A
If the player cannot read the disk it will not return the disk until it gives up trying.
Time will tell.
