Camping, Backpacking & Hiking Logo
Anonymous Posted on Jul 30, 2012
What material are sleeping bags made from? - Camping, Backpacking & Hiking
Cordelia Goldner
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 12, 2019
Cordelia Goldner
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
609
Points
12
They are the least durable of the synthetic materials and are best for car camping or general walk-in camping. Nylon, polyester, and taffetas are low cost and extremely breathable fabrics.
Lloyd Smedley
Level 1:
New Friend:
  • Posted on Dec 27, 2018
Lloyd Smedley
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4766
Points
12
Glenn Fitzgerald
Level 1:
New Friend:
  • Posted on Dec 26, 2018
Glenn Fitzgerald
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
664
Points
12
Sleeping bags can be made of materials like Nylon, Polyester, Taffeta. These are the most common materials used for mummy sleeping bags. They are the least durable of the synthetic materials and are best for car camping or general walk-in camping. Nylon, polyester, and taffetas are low cost and extremely breathable fabrics.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
22
Helped
3515
Points
27
Sleepingbags are made of a diverse range of materials and it depends where you plan touse your bag. Here's a really good article from a camping site that explainsthe different materials and what their benefits are http://www.my-favorite-camping-store.com/sleeping-bag-materials.html
1helpful
2answers
Should I hand-wash my sleeping bag?
Probably. I wash ours all the time. What is the material and filling? Down or feather bags are hard to wash and I like dry cleaning those.
For synthetic bags, load loosely in a top load washer or better yet use a front-load machine. The front loader tumbles the bag instead of using an agitator. Use minimum soap, and do an extra rinse. SPIN SLOWLY. You do not want the weight of the water to tear anything inside the bag. After it is done, then you can spin it faster because most of the water will be out. Then dry in the dryer. Some people say to put a couple of tennis balls in with it or an old shoe -- apparently to fluff it around a bit more.
tip
How to Choose a Sleeping Bag
You would think that it's a simple task buying a sleeping bag, but there are many factors to consider before making a decision.
Firstly you have to figure out why you are buying your sleeping bag: Is it to have for sleepovers in your house, is it for the kids, is it for camping trips or serious hiking outings? All these questions will affect how much you should spend and the weight and quality of sleeping bag that you buy.
Different Shapes
There are 3 basic sleeping bag shapes:
Traditional mummy style which has tapered ends and traps the heat well.
Rectangular style which are bulkier and less heat efficient but they can be unzipped, so not only can they be used as a blanket but also give more space to move around in.
Semi-rectangular style which is quite a good compromise between the 2 options above.
Choosing a Fill Material
There are 2 main types of fill material for sleeping bags; Synthetic or Down. Here are the pros and cons of both types.
Synthetic: These sleeping bags weigh a lot more than down filled bags and are bulkier but they cope much better with being wet as they retain their insulation well. They also dry quickly once wet and have better anti-allergic qualities. Finally, they usually cost a lot less, so if you are camping on a budget - this might be the filling for you.
Down: These bags are made from the fluffy undercoating of geese and ducks. It's a natural material as opposed to a synthetic one and it's really good at keeping you insulated and warm, so it's a good option if you are camping in cold weather locations. The quality varies depending on the bird the down comes from and there are measurements that tell you the quantity of down used in each sleeping bag. These bags are really compact and light but if they get wet they take forever to dry.
What else? Other things to consider when buying a sleeping bag are; Whether to get a lining with it which helps avoid the need to wash your sleeping bag too often. Also a sleeping bag mat which goes under the sleeping bag and rolls up very compactly can make all the difference to your sleep. Read the washing instructions to make sure you can put it in the machine or dryer. Enjoy your sleeping bag.
Is there a difference between indoor and outdoor sleeping bags?
Yes. An indoor sleeping bag is much cheaper and will not provide the warmth and comfort you would expect from an outdoor sleeping bag designed for camping/backpacking. Indoor sleeping bags are often referred to as slumber bags - generally used for childrens sleepovers.
2answers
Can I buy a simple sleeping bag for all of my outdoor use?
Technically, there are 3 types of sleeping bags for various uses outdoors - trail, trekking and mountain. Trail bags are great for short trips and ideal for inexpensive sleeping bags. Trekking bags are designed for longer use and are usually much more lightweight. Lastly, mountain sleeping bags are especially lightweight and are made with extra insulation.
2answers
What is a sleeping bag made out of?
Sleeping bags are covered with a shell thatis nylon, polyester, cotton, flannel, or a blend of these materials. Insulation. The next layer under the sleeping bag'sshell is the insulation. The insulation isolates a volume of dead space to forman 'insulated' area. There are several types of insulation material used insleeping bags. The purpose, temperature and price of the sleeping bag determinethe type of insulation. The most common are polyester fibers and goose down. Liner. The shell and liner enclose the insulation ofthe sleeping bag. The liner is is soft and made of common materials which varywidely
What is the best to care for my sleeping bag?
When not in use, sleeping bags should be kept away from high heat and away from moisture.
Store in a dry location in moderate temperature.
During use, try to keep the sleeping bag dry and away from open flame.
After use, air dries the sleeping bag outside for several hours.
Follow the manufacturer's instruction for cleaning the sleeping bag. Instructions differ based on the type of material and insulation.
Kelty redwing
make sure all straps (especially at the bottom) are pulled tightly. If it is an old pack then the material may just be stretched and there is nothing to do outside of get a newer bag. My pack also sags at the bottom but i just stuff my sleeping bag crammed into the bottom and it fills it out a bit and makes it less saggy. if the bag is not very old, then maybe there is a warranty on it.
Top Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
