Washing machine will not spin. you can hear it sqeaking like the belt is slipping.
Does it agitate for the wash cycle?
When you get to the spin cycle, is the motor running and 3 pulleys underneath turning, and the tub is not turning?
If so, I had this issue with this model. The brake would not release, and I had to "persuade" it. Also, I had to set the plastic cam correctly on the bottom of the unit to that is would engage and release the brake at the proper points.
Did not need a bearing kit, just had adjust a few things that got knocked around by the movers. Only took me 6 frustrating hours. Hopefully take you less than 1. BEWARE the 200# force for the spring!
Cost $0. Mental anguish = still tabulating.
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
SOURCE: WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
