How to dry inside hole where turn table goes in
Remove and use a hair dryer to dry the boards, it is important that ALL the water present within the board must be dried out.The board also can be removed and dried
Please check this link: Water in set
SOURCE: spilled some water on top ge micro wave while cleaning cabinets
YOUR BLOWER FAN MAY HAVE QUIT AND WITHOUT THE AIR CIRCULATION IT OVERHEATIND THE INTERNALS OF IT AND UNFORTUNATELY THIS UNIT WILL COST YOU MORE TO FIX THAN GETTING A NEW ONE. RED HOT IS VERY BAD ON A MICROWAVE
SOURCE: no heat micro keeps cycling through all programsdemo in cook/bx
My GE doesn't have a Demo mode but say we have a power failure. It won't let me use it until I set the clock.
Try that and see if it helps
SOURCE: GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
SOURCE: Microwave Circuit trips First:
The outlet with the red button is a GFI (ground fault interrupter) type. It may have been damaged when the microwave overheated. If so, it may trip when loaded.
You should do a full two minute heat test with a cup of water with the oven plugged into the standard type outlet that you tried second.
If it works fine, then i would suspect that the GFI outlet has failed and needs to be replaced. "When in doubt, throw it out", as they say.
The microwave does not need a GFI type outlet.
But do be sure the microwave's internal cooling fan is running properly.
When I say internal
cooling fan, I do not mean the hood vent exhaust fan which you can turn
on and off manually.
I'm instead talking
about the internal fan which comes on automatically whenever you microwave.
It is vital that the
cooling fan runs, or the magnetron will soon be destroyed.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If the turntable and/or inside light do not work when you cook, that's a bad sign, too.
If the microwave still fails in the standard outlet, it has a problem that needs to be addressed.
If you need further help, contact me directly or post a new detailed help request here and include your full model number from the tag on the oven.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
