The in car dvd player has a button that is supposed to angle the monitor in 4 different angles.. When I hold the button, It should change from angle to angle.. But when I hold the button down it just says "Angle 1" and doesn't change. If I push the button (not hold) then it just lays flat so i can put in/eject a disc... Someone help please, I already read the manual like 5 times
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
You need to have the remote in
hand. Insert a memory stick or SD
card that has the images you want to use.
When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set
of icons on the bottom. If you do
not see an icon with a hand, press the arrows that are in a circle until you
do. Once you see the hand, press
it one time. It will save the
image onto the internal memory.
You will find the image in the screen tab in settings, under all the
stock images.
Come on, no ones knows how to fix it?
